It is currently Wed Dec 31, 2025 2:55 am
PostPosted: Fri Feb 13, 2009 3:51 pm
Hi there I was wondering if anyone can give me an advise on how to add and more gain on the existing preamp gain and master volume and I also wanted to add a preamp in and out on the amp itself. I'm okey with adding some extra holes on the trinity.
Joe
http://sincitymusic.embarqspace.com/
PostPosted: Sat Feb 14, 2009 11:56 am
You can change the design to a TMB (details in the resource section); add the boost switch (late model sIIIs) or go as far as an sIII-One that rgtr made with a cascaded boost!! Posted somewhere in the forum with schematics & clips.
zaphop would had a lot of input on this for sure. :D
PostPosted: Sat Feb 14, 2009 12:56 pm
What would I know about that? :lol:
There's a couple of quick and simple mods you can do to the sIII. The first is to turn 100k resistor R8 around, so that it's now in series between the wiper of the Gain pot and pin 2 of V2. Next reduce the value of R9 to 820 ohms, like in a typical Marshall. Those two mods should give you plenty more gain. :D If that's still not enough gain, place a 1uF or 2uF cap across R9, but I think you probably won't need to do that. I would also be inclined to increase C1 to 0.01uF (10nF) to thicken up the tone a little more.
PostPosted: Sat Feb 14, 2009 1:48 pm
I am very happy that I got this amp. Basically sounds just like the old jmp that I use in the studio. I had it for 7 weeks now playing it almost everyday. Rest to sure I will do that procedure you gave me. Thank you so much for the advise.
Joe
PostPosted: Sat Feb 14, 2009 2:32 pm
Sounds like it could be a switchable option too!
PostPosted: Sat Feb 14, 2009 2:45 pm
I am actually very happy with this classic sound and I wanna keep the original tone trinity provided. I just wanna get a bit more kick out of the gain which I play alot of late 60's-70's especially the 80's. The amp is so versatile for my what i do. 99% I just dial the guitar volume down to get the old bluesy clean tone. Most of my guitars are electronically modified and it fits right in perfect to this amp. This is actually the first 18 watt I had. We'll along time ago I had an old traynor. But this is the one.
PostPosted: Sat Feb 14, 2009 6:10 pm
I suggest you first just do the R9 mod, and see if that increases your gain enough. If not, then also do the R8 mod.
PostPosted: Sun Feb 15, 2009 6:41 pm
I got the R9 gain done its perfect. I was extending myself on the effects send and return. for some reason I got a hum and I wasnt able to get back on it for some other iteniraries. This is the stuff I did.
http://www.trinityamps.com/ForumGallery ... s_Loop.jpg
Any ideas.
Joe
