It is currently Tue Jul 16, 2024 6:40 pm
PostPosted: Sun Mar 01, 2009 5:03 pm
VRM mode question for new V6 Dual Power Tube:
For VRM mode, if inputs are scratchy when VRM is on lower settings, I took the 1mg resistor off the input jacks and used them on V1 pin 2 and 7 to ground;
question, do I put jumper wires where the 1mg resistors were on the input jacks?
Dave in Portland Ore.
Love is a small Cat on your amp purring as you play
PostPosted: Sun Mar 01, 2009 7:12 pm
Take a look at the last two entries on this thread:
viewtopic.php?t=1176
In the "resources" forum under VRM
:D :D :D
 Post subject: INPUT JACK POLES
PostPosted: Sun Mar 01, 2009 8:12 pm
Dear jcny
I've done as per the pictures, the pictures don't anwser my question.
DO I PUT JUMPERS ON THE INPUT JACK POLES WHERE THE 1MG WAS?
THANKS FOR RESPONDING TO MY POST
DAVE
PostPosted: Sun Mar 01, 2009 8:48 pm
Sorry, didn't realize you had seen that reference.
My guess is no jumper on the input jack, hopefully Stephen will show up and tell us for sure.
PostPosted: Sun Mar 01, 2009 9:28 pm
Rwmove the 1M only, leave the link on the jack that went to ground from the end of the 1M resistor.
PostPosted: Sun Mar 01, 2009 9:45 pm
viewtopic.php?t=1176 has been updated to answer your question
PostPosted: Sun Mar 01, 2009 10:14 pm
JCNY, Sorry if I sounded short, I don’t compose so will when I type fast.
Again thanks for posting.
Stephen thank you, a picture is worth a thousand words to this old Fart.
Dave in Portland Oregon
PostPosted: Sun Mar 01, 2009 11:40 pm
Cosmo-one, No problem :P Just trying to help another Trinity fan.
Does the picture on the referenced thread come up for you, I get the dreaded "red x" :? :?
PostPosted: Sun Mar 08, 2009 8:15 pm
Hi Jcny
the picture for the VRM input mod there is a blank space with a red X, but i also get a the new posted VRM input mod picture too.
Dave
PostPosted: Sun Mar 08, 2009 8:41 pm
So do I now, thanks :D :D
How's the VRM working for you now?
PostPosted: Sun Mar 08, 2009 11:11 pm
jcny
I got the input mod done but both my amps Vrm don't work but the amps work, the V6 is too loud without VRM or master V for an apt.
Dave
PostPosted: Sun Mar 08, 2009 11:24 pm
I figure you probably have already checked this, but are you sure you have the insulator between the VRM module and the amp chassis?
The module needs to be isolated from the chassis.
Can you put up some pictures of the install? That would help in determining what the problem is so that we can help you get it up and running. :D :D
It's amazing how loud 18 watts can be :shock:
I have my SIIIv6 set with the gain (volume) around 10 o'clock and the volume (MV) set about 2 o'clock and keep the volumes on my LP back around 5 and it's plenty loud in my house.
If I open everything up, there's stuff rattling all over the house :D :D :D
PostPosted: Mon Mar 09, 2009 2:48 am
jcny
Yes, the V6 will shake rattle and roll the Apartment, love it :D but if the floor shakes wow. :shock:
I have good neighbors that get pissed if i don't practice my guitar but this might get old for them. there is a post at the front of this forum that tills where i'm at on the VRM, I did put the heat sink (gray pad) Under the mossfit and elictric tape under the eyelets so it's not shorting out. the V6 sii had no sound till i took the VRM out of the circuit then everything worked.
The TC15 has sound and works fine and the VRM is till in the Circuit but doesn’t work.
I'll look at it monday
thanks for the reply
Dave
