It is currently Tue Jul 16, 2024 7:34 pm
 Post subject: Basic (dumb?) question
PostPosted: Fri Nov 13, 2009 10:40 am
Quck question -- If I hook up speakers to both outputs, do I need to adjust the ohms switch? Example -- if I hook up two 8 ohm cabs to the two output jacks, do I set the amp at 8 ohms or do I have to adjust for series/parallel?
PostPosted: Fri Nov 13, 2009 12:44 pm
The two output jacks are wired in parallel, so two 8 ohm speakers in parallel would = 4 ohms... Adjust the impedance switch accordingly.
Joe G
Some assembly required,
Brain sold separately...
