Generally, it's not a great idea to rectify the heater supply, as often it introduces high frequency buzz noise into the amp. If you do a lot of filtering and regulation it can work, but just for the preamp valves. It's a lot of unnecessary complexity. Even some very high gain amps like the Soldano SLO 100 use AC filaments. Usually, keeping the heater wires away from the other electronic components, plus "DC elevation" of AC heaters works better. In this you apply a +ve DC bias to the heater supply. The simplest way is to connect the heater supply's centre-tap to the cathodes of the power tubes (in a cathode-biased amp).
_________________ Great tones come in small glass jars!
