It is currently Mon Jan 20, 2025 3:04 pm
PostPosted: Wed Jan 20, 2010 12:04 pm
........ Hi Guys - Denny from VT here. :D
I have a Ceri@tone 18-TMB that I'd like to mod to higher gain on the TMB channel, make it channel switching, and put in a GOOD FX Loop. Thanks in advance.
Denny :)
Denny
www.bluefrets.com
PostPosted: Wed Jan 20, 2010 2:03 pm
No suggestions from Ceri@tone?
How hi gain? You can:
- cascade channels
- buy an FX loop from Ironsounds
- get a channel switcher from BBQ
PostPosted: Wed Jan 20, 2010 3:24 pm
I never thought of asking NIK. I'll do that.
I'd like to make it fairly high gain similar to a boogie/soldano. I'll chaek out BBQ
Any idea where i can find out how to do the cascading "thing"?
thanks
D.
Denny
www.bluefrets.com
PostPosted: Wed Jan 20, 2010 3:31 pm
Ceri@tone does have a post for a simple non-buffered series FX loop on their mods page. It'll only work on one channel at a time in a 2-channel 18w though. Getting it to work on both channels is a much more intricate endevor (there's a thread here about that in fact).
You could always pop in two independent loops, or if you add a channel switcher you could rig a relay to also switch the loop between channels. Could get ugly in there! :)
I think either mojo or Metroamp sells pre-built switching networks.
BBQ's buffered loop kit will require an extra tube so make sure your PT can handle the extra heater current if you go that route. Probably won't be an issue but you never know. Not everyone overspecs everything like our Trinity pals! :)
BTW, BBQ also has a mod kit for adding a gain stage (or two).
For the cascading thing, check out this thread... viewtopic.php?t=1798
