It is currently Wed Mar 04, 2026 10:52 am
 Post subject: 240v VRM
PostPosted: Sat Mar 05, 2016 1:11 pm
Amp is running good, no hum hiss or smoke so I need to install the VRM but at 240V. Wiring in the PT was different to 120V with the standby switch so any suggestions of how to do this would be appreciated. Thanks in advance.
 Post subject: Re: 240v VRM
PostPosted: Sat Mar 05, 2016 5:17 pm
How was the sby switch wired differently than the 120 v version?
Might be wrong in this but the only difference should be wiring the power switch for 240v
vrm wiring should be the same as 120 v :hmmm:
PostPosted: Sat Mar 05, 2016 10:56 pm
VRM wiring is the same. You modulate the B+
The VRM control has a switch built in to replace the power switch.
PostPosted: Sun Mar 06, 2016 3:10 am
I'm a little out of my depth here. What do you mean by modulate Stephen? Thanks.
PostPosted: Sun Mar 06, 2016 5:19 am
Further problem is I've lost/mislaid the 5R 2W resistor. I need to get another but UK only seems to have 4.7ohm or 5.6 ohm. Any help would be gladly appreciated.
PostPosted: Sun Mar 06, 2016 9:06 am
modulate means just to adjust it. 4.6 R will do.
