It is currently Tue Jul 16, 2024 7:04 pm
PostPosted: Sat Jul 24, 2010 1:22 pm
Phase Inverter Voltages are way off and I've run out of ideas. It's so far off I think it must be something obvious. ...Not to me though. :) I'd appreciate any ideas, I'm just looking down the same dead ends here.
All the voltages are right on except all the DC on V3 (heater voltage is right and is measurable from the tube side of the socket).
1: 286VDC
2: .5VDC
3/8: 4.9VDC
6: 285VDC
7: .5VDC
Pre/Power and PI have had multiple tube swaps with the same results. Sorry about the mess, this thing looked a little more presentable before I started swapping parts and chopsticking like a hungry chimpanzee.
Illustration of the area in question:
Pictures of the whole thing (click to embiggen):
Thanks for any input!
PostPosted: Sat Jul 24, 2010 1:47 pm
WTF is that thing going on at the filter cap!
Is that a bunch of resistors in parallel to get up the power rating?
Some of the joints at the PI look a bit suspect. You might consider touching them up. Have you actually measured the resistors there to make sure they actually are what they are labelled?
PostPosted: Sat Jul 24, 2010 2:07 pm
It's that -and- it's modern art. I broke the ceramic one and put that there so I could keep working. It specs out pretty close though.
Will do. Yes, one of the '100's was really more like 140-something ohm and I changed that out for a closer-to-100-100 -now they're all pretty close.
Thank you!
PostPosted: Sun Jul 25, 2010 3:37 pm
R14 / R15 Swapped. D'oh! 470 vs. 470k
Thanks all!
PostPosted: Sun Jul 25, 2010 5:41 pm
Called it :D
Glad you found it. Those yellow vs brown bands can be hard to distinguish on the CC resistors.
PostPosted: Mon Jul 26, 2010 11:53 am
Good plan to test them before you install them.Esp the 470 / 470K ones. I should note that in the manual!!
PostPosted: Mon Jul 26, 2010 1:54 pm
Yeah - it's an easy mistake to make. I made a similar mistake in the reverb mixer of my BFDR clone. Took me quite a while to figure that one out!
SG + Brit tube head = Nirvana
PostPosted: Mon Jul 26, 2010 2:41 pm
It's amazing how hard it is to catch one's own mistakes!
Thanks everyone,
bumper
