It is currently Wed Jul 17, 2024 1:29 am
PostPosted: Wed Oct 13, 2010 8:24 pm
Hi all,
I'm working my way through the initial fire up of the plexi-v6. I've got continuity at all points that lead to ground. The heater leads are all within spec. I install the rectifier and get 440v on its output lead on the can cap. I proceed to check the plate voltages and get basically nothing. Now what? I'm hoping that whatever it is isn't on the underside of the turret board!!!
Now that my first mistake if fixed I've got 420v at the plates. Yikes! Can't be right.... can it?
Lee
 Post subject: hold the phone
PostPosted: Wed Oct 13, 2010 10:09 pm
I see a bad solder at the can. Logical. We'll see
Well, now I'm getting 420v on the plates at each socket (no tubes other than the rectifier).... Any thoughts?
Lee
PostPosted: Thu Oct 14, 2010 6:57 pm
It's Right on! Once you put in all the tubes, it will drop to 340-350 V .
PostPosted: Thu Oct 14, 2010 9:44 pm
Indeed! It is rockin! My neighbors have already texted me to tell me it is working. Now, I'm trying to talk my wife into a tc-15 now.....
Thanks for the feedback.
Lee
PostPosted: Thu Oct 14, 2010 9:54 pm
Awesome. So your neighbors helped too!
PostPosted: Thu Oct 14, 2010 11:59 pm
Yes they did! They came over and helped me celebrate the birth. My next question is, why is it so quiet? No hiss or hum, I'm pretty stoked at this point, despite my poor soldering. (3 cold ones easily discovered with a multimeter).
Thanks Steven,
Lee
PostPosted: Fri Oct 15, 2010 11:00 am
Good tubes, good parts, good layout! Good Work!
Users browsing this forum: Google [Bot] and 20 guests
