It is currently Wed Dec 03, 2025 9:34 pm
PostPosted: Thu May 05, 2011 6:27 pm
Anyone know the actual EXTERNAL dimensions for the head cabs?
PostPosted: Fri May 06, 2011 11:33 am
A trinity head cab made for an 18w is 22wx8 1/2dx8t not including the feet or handle.
Tele's make the best noise
PostPosted: Fri May 06, 2011 11:35 am
viewtopic.php?f=12&t=1249
PostPosted: Fri May 06, 2011 1:39 pm
Stoo wrote:
http://www.trinityamps.com/phpbb/viewtopic.php?f=12&t=1249
The purple head cab is made by Trinity and the external measurements are as I gave above for that cab. It is for an 18w.
It basically tells you, that depending on builder, heads may be made to various sizes. That minimum size will be determined by chassis and transformer size. Big tubes need more clearance and also influences size. I like the 22" width because my 112, 115, 210 and 4x8 have all been made to 22" wide.
Measurements are 24"w x 8.75 h x 8.25 deep.
Thats the size that the plan Stoo linked shows and the size of the white triwatt cab I bought from G-log
I built this cab last year and now have no use for it.Marshall white Levant with gold braid piping. 1/2 baltic birch ,finger jointed with a Hiwatt style handle. Aluminum foil tape on the bottom for shielding . Measurements are 24"w x 8.75 h x 8.25 deep. Like new.Never taken out gigging.It fits a Triwatt or 18W chassis. Rear panel is velcro attached for easy removal
Images here
viewtopic.php?f=6&t=2276&p=20565#p20565
