It is currently Sun Jan 25, 2026 2:36 am
 Post subject: Quick wiring question
PostPosted: Sat Aug 13, 2011 11:48 am
The insulated wire that goes to V2 pin two. Do I twist the inner and outer wires together and solder to pin two?
Rich
PostPosted: Sat Aug 13, 2011 12:39 pm
See this topic -it will help you
http://www.trinityamps.com/phpbb/viewtopic.php?f=2&t=1144
PostPosted: Sun Aug 14, 2011 2:51 pm
Inner is the signal wire. "Outer" is the shield. That other thread shows you a handy way of separating the shield from the inner wire AT THE END THAT YOU GROUND. At the other end, you don't solder the shield at all.
PostPosted: Mon Aug 22, 2011 10:14 pm
Thank you.
Rich
