It is currently Wed Oct 22, 2025 12:59 pm
PostPosted: Sun Aug 14, 2011 12:14 am
Well, I finally placed my order, so looking forward to building, and hopefully ending up with, a working amplifier when I'm done. Anyway, looking for ideas on the following stuff:
Tube Socket Size and Source?: There seems to be 7/8(1-1/8) size and 3/4 size for 9 pin sockets? Which one works for the Trinity?
Source for the 120v Pilot Light? I found one on the Hoffman page, anyone else try it?, will it fit?, it's "square" on light end? Mouser sells one with a 5/16 hole as well that is rounded.
On Switches? I see a couple of different kinds? SPST and SPDT, which to use for the Mains/Stand Switches :) and the Mini Toggle?
Thanks in advance...only took me 6? years to start this.
PostPosted: Sun Aug 14, 2011 3:51 pm
If you ordered a kit, isn't all of this stuff already included?
All I had to buy for my head kit was a set of tubes.
PostPosted: Sun Aug 14, 2011 7:20 pm
Hi, I went with the Trinity Chassis, 18 watt Trans Set, and Stuffed Board( to save some time).
I think I found the answer on the Tube socket size after searching some old posts...and I guess Mouser sells the lamp, although I may go with square one who knows.
I just need an idea on the switches?, looks like most people are using fender style for the mians/standby...I'm not sure what to use for the mini toggle, I found one, it says
Parts Express Mini Toggle Switch - DPDT On/Off Type. I think that is what I need.
Fun stuff.
