It is currently Sun Jan 25, 2026 11:14 am
 Post subject: Bad OT???
PostPosted: Thu Sep 01, 2011 10:01 pm
I noticed yesterday when I put in new output tubes that my output plate voltages are off. I have 320vdc on pin 7 of V5 but only 299vdc on pin 7 of V4. I have 305vdc on pin 9 of both V4 and V5. B+ is 327vdc.
Is there something wrong with my OT?
Les
 Post subject: Re: Bad OT???
PostPosted: Sat Sep 03, 2011 11:44 am
Any ideas? Is there a way to test the OT for shorts or something? What should the resistance reading be on the OT primaries, secondaries?
Les
PostPosted: Sat Sep 03, 2011 12:24 pm
Well..start by bleeding off the caps for safety. measure the resistance of each half of the primaries (from the plate connection to the B+ connection). They should be about the same...afew 10's of ohms each. Also check that there is no continuity from the primary leads to the metal housing or laminations. Same for the o/p windings. The individual taps on the o/p will have even less resistance. There should be no electrical connection for any o/p winding to any primary winding.
PostPosted: Sat Sep 03, 2011 3:39 pm
viewtopic.php?f=12&t=1490
Tele's make the best noise
PostPosted: Sat Sep 03, 2011 10:27 pm
Are you sure both power tubes are OK?
PostPosted: Sun Sep 04, 2011 12:57 am
Stoo, Taz13, Thanks. I tested the OT and things seems to check out ok. (although I did not do any advanced testing so there still might be a problem there.)
Yes. I now have 2 sets and both sets have the problem even if I swap tubes from v4 and v5.
Les
PostPosted: Sun Sep 04, 2011 1:26 am
After testing the OT I set all controls to 5, powered up and checked my voltages. I got 327vdc on both V4 and V5 plates. :hmmm:
I set the gains at 10 and PPIMV at 8-9 and I got 305vdc on V4 and 325vdc on V5. :hmmm: :hmmm:
I set the PPIMV back to 5 and I got 325vdc on both V4 and V5. :hmmm: :hmmm: :hmmm:
With the PPIMV at 7 or below I get 325vdc on both V4 and V5 but with the PPIMV at 10 I get 288vdc on V4 and 325vdc on V5.
I am now sure this is what is causing my severe blocking distortion problem with the PPIMV above 7.
Question is.... what is causing the voltage to drop in V4 when I turn up the PPIMV? :?
Les
PostPosted: Sun Sep 04, 2011 1:30 pm
I suspect ultrasonic oscillation, which is overloading one of the power tubes. If you check in the dark, you may even find that V5 red-plating.
PostPosted: Sun Sep 04, 2011 6:09 pm
I have narrowed it down to V1a. As soon as I start to turn up VR1 (bright channel gain) the plate voltage starts to drop in V4. The normal channel is fine i.e. there is no effect on V4 plate voltage when I turn up VR2. I have tried different tubes in V1 with no improvement. Also no other controls (other than PPIMV) seem to affect the V4 voltage.
I am going to try removing the cascade and send the input straight to V1a and see if that helps.
Edit: I am going to continue this on my Plexi brown - fizzie when dimed thread (viewtopic.php?f=7&t=2978) as it is that issue that I am tracking down.
Les
PostPosted: Mon Sep 05, 2011 1:23 am
Is the output from both sides of the PI equal????
PostPosted: Tue Sep 06, 2011 11:44 pm
Possibly not, after the parasitic oscillation starts to kick in.
