It is currently Sun Jan 25, 2026 11:14 am
PostPosted: Mon Sep 05, 2011 6:36 pm
This is perhaps a really stupid question - I looked for a bit for an answer but thought I would post it even though I may look a little dim for asking
these amps are known as 18 watts..
yet if the el84's are dissipating 12 watts+ each is that not 24 watts?
I assume that amps are rated as per some other nominal wattage specification but was curious how they came to be known as 18 watt amps
PostPosted: Mon Sep 05, 2011 7:32 pm
I could ask a way more stupid question then that. Just you wait and see.
Rich
PostPosted: Mon Sep 05, 2011 9:30 pm
You don't bias to full 100% plate dissipation. 70=65%-85% in cathode bias is more common. You actually bias hotter with cathode bias amps.
So if you run those numbers on 12W and multiply by 2 you get pretty damn close to 18W. 17W, 19W, 20W it all sounds the same though!
PostPosted: Mon Sep 05, 2011 10:21 pm
I thought that is actually plate dissipation wattage not amplification wattage? Two different things? :? :hmmm:
Les
PostPosted: Tue Sep 06, 2011 11:59 pm
Yes, there is very little direct correlation between anode dissipation watts and power output watts. Depending on the class of the power amplifier, the output watts get higher relative to the dissipation watts. In theory a true Class A amp can push out 49% of max anode dissipation under ideal conditions. Class AB amps can put out more, and so on with Class B and Class C, etc. So if the Marshall 18W and Vox AC15 were true Class A amps, they would be able to put out a little under 12W at very best.
