I had thought the lower "h" value of the Marshalls made them looser than amps like SLO's or others with 10 h or higher chokes - not so much the placement of the choke.
Hiwatts (and the Triwatt) are very stiff amps, probably more so than a SLO. And they have no chokes at all. The stiffness comes from the lack of choke and also the large filter caps. A SLO would be even stiffer if you took the choke out. One of our forum members here, in fact built a Hiwatt with a switchable choke, and reported on this difference with the choke in and out of circuit. What a choke does is fight against changes in current flow, by changing the voltage across the choke itself. So with rising current a magnetic field in the choke generates a voltage which counteracts that rise in current, and vice-versa for a falling current. So if a choke is feeding the screen supply it will tend to counteract fluctuations in screen current, thus making a power stage feel softer and more compressed, although the effect will be somewhat offset by a large value second filter cap. With a smaller choke and very large 2nd filter cap value, the amp will feel pretty stiff because the cap is dominating over the choke.
I placed the 4h across the first filter cap can in place of the resistor - as per the 18 watt mods in Tube Depot's kit instructions - seemed like an easy way to install though I was uncertain as to the best way to install and could not find any 18 watt specific choke install schems or layouts
So it sounds like you installed the choke between where power is fed to the OT and to the screen grids. So the choke is basically regulating the screen supply. Anyway, what made Tube Depot any kind of authority on Marshall 18W amplifiers?? Personally, I would get rid of it, and go back to the stock 18W circuit.
