It is currently Wed Mar 04, 2026 1:44 pm
 Post subject: channel jumping
PostPosted: Tue Feb 05, 2013 12:53 pm
what is the easiest way to switch phase to channel jump on these amp?
just curious...would running a separate OD pedal on top of the amp be the easiest, with the gain turned down?
 Post subject: Re: channel jumping
PostPosted: Tue Feb 05, 2013 2:00 pm
The phase of each channel is the same (inverted compared to your original signal) so you can just jumper them and not have to worry.
PostPosted: Tue Feb 05, 2013 2:45 pm
well...that makes it easier...sorry, i was under the impression they were out of phase already...and before i made some cables for a pedal i wanted to clarify
