PostPosted: Thu Aug 01, 2013 6:37 pm
:) Hello, Does anybody have some simple layout plans and measurement for a 1x12" combo amp cabinet build in which a 18 sIII head chassis mount on top of speaker cab and controls front face and tubes face up like a Suhr Badger 18 watt amp in a closed back with ported type cabinet. Thank you.
PostPosted: Fri Aug 02, 2013 12:01 am
We don't have this, but a recent customer posted pictures of his that did. See if you can find that post and ask him.
PostPosted: Wed Aug 07, 2013 9:58 pm
:? No replies!
PostPosted: Wed Aug 07, 2013 10:22 pm
:) Hi friends, Could anybody please post your schematics or pics of a Combo amp cabinet build with head chassis and tube mounted upwards. I think this cabinet design greatly benefit tubes long life, chassis and components heat rising issues and protect from speaker and tubes vibration interference which cause early tube rattles and microphonic issues etc. overall a cool look combo. thanks Vinu
PostPosted: Wed Aug 14, 2013 3:48 pm
:roll:
PostPosted: Wed Aug 21, 2013 7:40 pm
Hey vinu were u able to get any layouts or plans?
Skip Jack
PostPosted: Thu Aug 22, 2013 7:14 am
I had someone else build my cab. I can take some measurements if you'd like.
PostPosted: Thu Aug 22, 2013 3:02 pm
Thank you BeachBob for posting the pics, your cabinet looks very nice. Please post me its measurements and schematics all you have. Vinu :)
PostPosted: Fri Aug 23, 2013 1:51 pm
It's too bad you couldn't get an upside down front panel and mount it with the controls on top. Would make for a much shorter overall combo if the tubes and transformers poked down towards the speaker instead of requiring their own box.
PostPosted: Sat Aug 24, 2013 10:50 am
The chassis compartment is very tall, it could easily be made shorter, but there is an overall balance and proportionality in doing it this size. In addition, you could quite easily use a 15" speaker instead of a 12" with this as well.
I'd be really concerned with an upside down mount due to heat build up. Those tubes heat up quite a lot; I'd suspect you'd have a lot of problems with it.
PostPosted: Sun Aug 25, 2013 3:24 pm
Hi BeachBob, your cabinet dimensions please. Thanks Vinu
PostPosted: Mon Aug 26, 2013 1:53 am
Loads and loads of combo amps with the controls on top have the tubes facing down. Pretty much all BF and SF Fenders, Boogies, etc.
