It is currently Wed Mar 04, 2026 1:28 pm
 Post subject: speaker independance
PostPosted: Wed Jan 29, 2014 1:28 pm
I am finally getting ready to start my 18 watt Plexi build with the VRM that I purchased from Trinity last June.
I have decided to build a 2x12 cabinet for the speakers, which have not been chosen as of yet. When I start my build which ohm should I wire the speakers too? Most of what I have read is 8 ohm.
I have been told to get speakers with 16 ohm and wire them in parallel to give it 8ohms. or should I wire the amp directly to 8 ohms and wire the speakers in a series???
I tried going through the threads but could not find the answer.
Thanks for your help, if all goes well I should start in about two weekends and have many more questions.
Thanks again,
Skip Jack
 Post subject: Re: speaker independance
PostPosted: Sun Feb 02, 2014 11:17 am
The output of the amp is selectable via a switch 4 8 16
Ive heard its better to wire the cab for 16 ohm as the whole output tap is used
for me I like 16 just cause i some time use two 16R cabs and set the selector on the amp to 8R
Two speaker in a cab would be
Sp Imp / par /ser
4 / 2 / 8
8 / 4 / 16
16 / 8 / 32
PostPosted: Wed Feb 05, 2014 2:16 pm
I appreciate the response, I looked at my different speakers and because of the moola I ended getting (2) G12m both are 16ohm and I will wire in Parallel for a 2x12.
I hope I made a correct decision.
Skip Jack
PostPosted: Mon Feb 10, 2014 12:56 pm
Skip Jack
That would be very normal practice. No worries there.
