PostPosted: Mon May 26, 2014 9:35 am
Hi all, I received new kit and am in the process of building the plexi mkii
I found cap c10 missing while building the board. The schem calls for 50uf 50v. I can find a
47uf locally, is that close enough. I see talk on here says use 220 uf in this position.
What value is suggested and what do the values do sound wise in this position?
PostPosted: Mon May 26, 2014 11:07 am
47uF is more than fine
Most electrolytic caps are +/- 20% tolerance anyways.
PostPosted: Tue May 27, 2014 8:25 am
Sorry the part was missing. We have used both 220 and 50 and recently went back to 50. 47 is fine too.
PostPosted: Tue May 27, 2014 9:47 am
Not a problem, 47uf it is then.
I cut off the extra lengths of leads from components going through the turrets, can I
reuse some of those for the jumpers between turrets?
PostPosted: Tue May 27, 2014 10:15 pm
Yes, I do it all the time?
