It is currently Wed Mar 04, 2026 10:51 am
PostPosted: Sat Jul 18, 2015 9:50 pm
I had just about everything I needed & it being a quite easy to go from the standard turret red board plexi to the tmb .
Had a brief listen & I can hear a little more gain on tap
I unhooked the boost switch as it is not on the TMB layout
One thing I didn't have was C1 .0047uf cap but the C1 in the plexi schematic calls for a .022uf & I've previously changed it to a .01uf cap (Not sure but I believe I changed the .022uf it was to tighten up the bass ) so I left the .01uf as is .
I will report back when I can crank her up
PostPosted: Sat Jul 18, 2015 10:02 pm
Haha.... I just noticed that on the TMB they use a 1MEG volume pot & my plexi has the 500k pot I wonder how big of a difference the 1 meg pot will make
PostPosted: Fri Jul 24, 2015 12:05 am
Big difference. The 500K is not a perfect impedance match for the previous stage, 1 meg is. So if you replace it , there will be more push (crunch) through the amp.
