It is currently Sun Feb 01, 2026 2:17 am
 Post subject: A question of jumpers
PostPosted: Sun Nov 27, 2005 6:02 pm
OK, so I now have an sIII 18 Watt TMB which is more or less where I had set out for some time ago but got waylaid with another design. I have a wealth of tones at my disposal and I have heard that these can be augmented by jumpering. Now I am presuming that a jumper would be a short piece of shielded cable with two jacks with the ground only attached at one end? What inputs does convention tell us to jumper? My guess is I stick my guitar into the Hi of the normal channel and then jumper the normal lo to the TMB Hi?
Nigel
PostPosted: Sun Nov 27, 2005 7:05 pm
Just a regular guitar cable. Go from/to either the Hi or Lo because all you're doing is parelleling the two channel inputs. Enjoy !
PostPosted: Sun Nov 27, 2005 8:53 pm
Great I will give it a go tonight. :D
Nigel
PostPosted: Sun Nov 27, 2005 11:21 pm
When designing my faceplates for my sIII...
I *almost* went with two inputs, hi and low....both going to v1 and internally jumpered between pins 2 and 7. And depending on whether I wanted one channel or the other, or a mix of the two....would dictate where I set the volume knobs on each channel...i.e. if I only wanted to play the normal channel, the volume on the tmb channel would be all the way down, etc...
I decided to stick with the 4 main inputs...but it definitely ocupied my thoughts for a few days...
-F
PostPosted: Mon Nov 28, 2005 12:22 am
I was considering putting a jumper switch on the back of the amp however decided against it as it was just another join that could introduce unwanted noise.
Nigel
PostPosted: Mon Nov 28, 2005 2:15 pm
Stick with the basics guys! That's the ticket!
