PostPosted: Tue Aug 25, 2015 3:59 pm
I am putting togeather plexi-V6 Trinity kit. Great stuff! I'm wondering if anyone sees a problem with mounting the terminal strip that goes to the back screw on V1, (the one next to the wall) in the open space between V1 socket and the componet main board. It is such a tight fit when it is in the back corner. I have it kind of cocked off to one side now and I could use it this way but I don't see a problem with mounting with new hole and screw out in front off to the wall side. Any problem with noise or any other issues. Any thoughts will be appreciated
PostPosted: Tue Aug 25, 2015 8:38 pm
I thought about drilling a new hole too.... It is such a tight spot to put the two inputs... with the 3 resistors and capacitor per input... and you need to watch that you do not ground anything when you put the mounting bolt through the hole as well.. I shortened my bolt to make it just long enough to clear the blind nut without going near the wires from the components... I think on the next build i will move the terminal strip out of the corner....
PostPosted: Tue Aug 25, 2015 10:50 pm
Thanks for the reply, any thoughts on electrical noise issues. I was hoping the Holy Ghost might have a some idea about this also, will wait for him to look in on the forum
PostPosted: Wed Aug 26, 2015 5:56 pm
You won't have noise issues.
Keep your lead dress neat, wires short and you'll be fine. Try to get the grid stopper resistors as close to the tube socket as you can.
PostPosted: Wed Aug 26, 2015 11:36 pm
Thanks for the reply, I also wondered about the sheilded wire to V2 alot of people run it over the comp board, can you run it under the board with no issues
PostPosted: Sun Jul 22, 2018 10:06 pm
SPAM!!
