It is currently Mon Apr 13, 2026 5:05 am
PostPosted: Sat Jan 30, 2016 11:43 pm
Hello all! I'm doing a scratch 18 watt Plexi MkII build and need to bounce a couple of things off you guys along the way if that's ok. My wife bought me a 18 watt kit from another vendor for Christmas but I have no use for tremolo and I have been wanting to do a 18 watt TMB. The Plexi MkII looks to be exactly what I've been wanting to build. Anyway, I've attached a DIYC file that shows a pic of how I want the board to look, well, you'll get the idea at least. I've got a board from Modulus that I'm trying to make work and I'm trying to keep a traditional/vintage-ish look to it. I'm also not going to use a boost switch. I'm just going to go ahead and place the .68uf in parallel with the 820R permanently. Can you guys take a look at it to make sure it will work? Let me know if there are any issues with viewing the file. Any help would be greatly appreciated and thanks in advance!
18 watt plexi revision 3.pdf [10.42 KiB]
Downloaded 798 times
PostPosted: Sun Jan 31, 2016 10:42 pm
Looks OK from a quick glance. You should label where each component is going.
