It is currently Wed Jan 21, 2026 11:57 pm
PostPosted: Fri Sep 02, 2016 1:39 pm
After a while, TMB channel cuts out but normal still works fine. With VRM right up I can just about hear the TMB but when first switched on both are the same. It's happened a couple of times now when adding the pedal board but that works with other amps and it seems strange that it only affects one channel. I've fudged around with a stick and seems ok!
PostPosted: Sun Sep 11, 2016 12:14 pm
It's definitely a problem when plugging in the pedal board- but only with the TMB channel which comes back in when VRM is up to half or more. Any one else had this?
PostPosted: Wed Sep 14, 2016 10:57 am
probably a bad solder joint on the TMB side. When it happens, leave it on and then measure the voltage to see if there are at spec or not. Good to do when it is working fine as well.
could be a bad tube too.
PostPosted: Thu Sep 15, 2016 7:30 am
changed the tubes and all is well. took it for a spin last night and sounded great,
PostPosted: Thu Sep 15, 2016 11:10 am
Do you know which tube fixed the problem? If it was just TMB channel, I suspect the cathode follower tube, V2
PostPosted: Sat Sep 17, 2016 1:47 am
Sorry, no. I changed all three. Just wanted to get it going again.
