It is currently Wed Jan 21, 2026 7:12 pm
PostPosted: Fri Jan 20, 2017 3:46 am
Hello
Both normal and TMB channels on my TMB build have close to 0 overdrive saturation, even with preamp volume maxed out.
The clean sound is really good, I admit, but I cannot get any overdrive. The only overdrive appears with high output humbuckers and master volume at noon or more - then some signs of (slight) crunch appear.
I assume this is a preamp issue. Power amp to me works as it should.
I tried to trace the board for errors, I did not find anything apparent.
The amp is loud and clear, no buzz, noise etc - all seems OK except the lack of darn distortion.
Can you tell, from your experience, the possible culprits/typical causes of such behavior?
I will check again the components values, connections etc but any suggestions are welcome.
Gitarzysta
PostPosted: Fri Jan 20, 2017 5:32 pm
Can you tell me what the voltages one the 12AX7s are, and if the bypass capacitors are in place as peer layout? Actually, allthe voltages would be good to know.
