It is currently Mon Jan 19, 2026 2:25 pm
PostPosted: Fri Apr 28, 2017 12:01 pm
I had planned to DIY the head cab for my amp, but now realize that I have less interest and talent in woodworking than electronics.
Anyone know of a relatively easy way to put together a head cab for the 18 watt amp? I can do simple sawing, drilling, but not joints or anything fancy that can't be done with a circular saw.
Thanks.
PostPosted: Fri Apr 28, 2017 9:02 pm
Sorry, I don't know of an easy way to make a good looking cabinet without a table saw and a router.
You could look at your local building center for pine shelving that's the appropriate width. Then cut it to the desired sizes (or have the building center do it if they offer that service) and simply glue and screw it together.
Or better yet, see about getting one of Trinity's spiffy cabinets!
PostPosted: Tue May 02, 2017 8:57 am
There is no easy way really. Easiest would be to design it wide enough to connect corners to cleats with inside screws. You still would want to round over the corners though.
Users browsing this forum: No registered users and 52 guests
