It is currently Thu Apr 09, 2026 12:21 pm
 Post subject: Board wiring
PostPosted: Thu Apr 27, 2006 3:40 pm
Newbie question here. I getting started wiring the board up. Just finished with the underboard connections. As far as the connections on the bottom that go out to the other components on the amp, do you guys recommend soldering these before all the caps and resistors on the topside, and if so should I just cut them all to some generic length then trim up to fit afterwards? I appreciate any help you can provide. Thanks.
PostPosted: Thu Apr 27, 2006 4:30 pm
classa30,
I suggest you solder components on first. wi Then solder on the leads to the underside with about 6" for the tube side and maybe 7" on the control side.
If you solder the leads on the top side, wrap them around the turrets= and solder.
