It is currently Tue Dec 02, 2025 3:41 pm
PostPosted: Tue Jun 13, 2006 11:32 am
Gathering parts for a sIII. Was going to use SOZO caps but picked up some mustards instead. However............ I picked up the .027 fairly cheap. Any issues / concerns / problems with using a higher value? If I use these would I need to adjust the value of any resistors?
Thanks for any / all responses!
Kenny.
PostPosted: Tue Jun 13, 2006 10:34 pm
They will be fine, should sound really good.
Nigel
PostPosted: Wed Jun 14, 2006 6:51 am
They will be fine. The tolerance on capacitors will be low, so they will work perfectly. No worries.
