It is currently Wed May 15, 2024 11:29 am
 Post subject: 18 Watt - Fizzy Decay?
PostPosted: Sun Sep 27, 2020 11:26 am
I've been enjoying my Plexi 18W (with VRM) for a few years now, but have noticed that there's a fizzy/buzzy decay to the notes. A quick google search..apparently this is a known issue with EL84 18-Watters, crossover distortion perhaps?
Has anyone else experienced this issue? Apparently there's a Paul Ruby mod that employs a few Zeners to help snub crossover distortion.
PostPosted: Wed Sep 30, 2020 3:05 pm
There’s a whole thread on this. forum about chasing down the fizzies. I’ve never had the pleasure!
PostPosted: Sun Oct 25, 2020 8:15 am
I've changed many new mica caps in the last few months. Whenever I get a strange sound that puzzles me It's usually the mica cap in the tone stack. Even in locations where there is no voltage (treble bleed), their just noisy, maybe I bought a bad batch. Fixed the problem every time. I'm not saying this is your problem but it's with looking into, or to keep in your pocket.
PostPosted: Sun Oct 25, 2020 10:49 am
What are you using to replace Silver Mica?
PostPosted: Fri Nov 27, 2020 10:29 am
I'm either finding a good one or using used ceramic disc.
PostPosted: Tue Jan 03, 2023 11:32 pm
I think I should look for used ceramic dishes, it will save quite a bit of money.
among us
PostPosted: Tue Jun 27, 2023 12:21 am
The Paul Ruby mod you mentioned is a popular modification that aims to reduce or eliminate crossover distortion in EL84 amplifiers. This mod typically involves adding wordle a few Zener diodes to the circuit to help snub the distortion and improve the overall tone and response.
PostPosted: Thu Aug 24, 2023 10:01 pm
The fizzy or buzzy decay in the notes of your amplifier's sound could indeed be related to crossover distortion, which is a phenomenon that occurs when the signal transitions between pizza tower the two halves of a push-pull amplifier stage, such as the output stage in a tube amplifier like your Plexi 18W. Crossover distortion can cause the signal to sound clipped or distorted during these transitions.
