It is currently Mon Mar 09, 2026 10:59 pm
PostPosted: Sat Feb 13, 2021 6:10 pm
Anyone have thoughts on covering the tube filament wires with conductive film to reduce 60 hz hum? Same stuff commonly used to shield guitar electronics....???
PostPosted: Thu Nov 14, 2024 11:48 pm
among us online
Using conductive film, like the shielding material often used in guitar electronics, could potentially help reduce 60 Hz hum by acting as a Faraday cage to block electromagnetic interference. However, effectiveness depends on the quality of the film and how well it’s applied. Make sure it's grounded properly, as shielding only works if it has a path to discharge the unwanted interference. It’s worth testing, but also consider other common noise reduction methods, such as grounding the tube circuit properly or using a hum eliminator.
PostPosted: Wed Nov 20, 2024 11:44 pm
PG-Shorty wrote:
Anyone have thoughts on covering the tube filament wires with conductive film to reduce 60 hz hum? Same stuff commonly used to shield guitar electronics....???bitlife
Using conductive tape (like copper) over 6.3V heater wires can help reduce 60Hz hum by shielding, but it must be properly grounded to work effectively. The tape needs to be heat-resistant and securely applied. However, twisting the wires and routing them away from sensitive areas is usually a more effective method for reducing hum.
PostPosted: Mon Nov 25, 2024 3:28 am
makerpodiatrist wrote:
PG-Shorty wrote:
Anyone have thoughts on covering the tube filament wires with conductive film to reduce 60 hz hum? geometry dash lite offers achievements and rewards for completing levels, collecting coins, and achieving high scores. Same stuff commonly used to shield guitar electronics....???
I agree, grounding the tape is key! I’ve used copper tape before, and when applied correctly, it really can cut down on interference. For those working in DIY projects, it's also worth mentioning that the tape should cover the wire completely without any gaps to prevent leakage of the signal. :thumbsup: :thumbsup:
PostPosted: Wed Nov 27, 2024 12:26 am
Using conductive film to shield filament wires could potentially help reduce 60 Hz hum, as the conductive material can act as a shield, preventing electromagnetic interference from affecting sensitive components. This technique is similar to what is used in shielding guitar electronics to reduce noise.
retro bowl
