It is currently Tue Mar 10, 2026 12:36 am
 Post subject: Speaker Questions
PostPosted: Mon Feb 08, 2021 8:27 pm
I'm planning on ordering the 18 watt sIII kit when it is back in stock. I'm planning on building a head and a 2x12 cabinet. I've read that in order to take full advantage of the output transformers, the speakers should be 16 ohms. Is there a noticeable difference in these amps if the speakers are wired as 16 ohm vs 8 ohm (series vs parallel wiring I believe it's called.) I'm trying to understand whether not there are advantages or disadvantages to either speaker wiring setup with this amp.
 Post subject: Re: Speaker Questions
PostPosted: Thu Feb 11, 2021 10:07 am
The differences in that will be subtle, in my opinion. I did the same setup and bought 2 8 ohm speakers. I have my cab wired up where I can choose both in series (16 ohm), both in parallel (4 ohm), or either speaker at 8 ohms. If you want options, you could try something like that. Otherwise, pick a setup and don't worry about it again. i think you would hear and feel more differences in tone with fluctuations to your line voltage.
-Dan
PostPosted: Fri Feb 12, 2021 1:35 am
There is a popular school of thought that 18W transformers like 16 Ohms best... I never really paid much attention. I agree with picking one that makes sense for your gear setup and going with it.
PostPosted: Sat Feb 13, 2021 2:45 am
-Dan
I did some more research after posting my question and basically came to the same conclusion you've presented here. Can you point me to any information on how you wired your cabinet?
Mark
PostPosted: Mon Feb 15, 2021 11:11 am
I think if you search online you should be able to find some series/parallel switching diagrams. But I took the easy way, I had Guitar Cabinets Direct build my cab and include this jack setup: https://www.amplifiedparts.com/products/jack-plate-plug-and-play-mono-stereo
It was really simple to hook up speakers to it, I loaded the cab myself.
Good luck and let us know how it sounds!
-Dan
PostPosted: Thu Jul 06, 2023 5:51 am
Nice, this is the problem i posted, luckily i have an answer for it now.
world of mario
PostPosted: Wed Feb 14, 2024 10:21 am
There's a widely held belief that 18W transformers, such as 16 Ohms, are optimal. Personally, I haven't given it much consideration. I align with the idea of choosing one that suits your gear setup and sticking with it. Descargar WhatsApp Plus v12 APK
PostPosted: Fri Feb 23, 2024 12:51 am
dbharris wrote:
I think if you search online you should be able to find some series/parallel switching diagrams. But I took the easy way, I had Guitar Cabinets Direct build my cab and include this jack setup: https://www.amplifiedparts.com/products/jack-plate-plug-and-play-mono-stereo geometry dash
-Dan
It sounds great, thanks
PostPosted: Tue Dec 17, 2024 12:39 am
mkel201 wrote:
I'm planning on ordering the 18 watt sIII kit when it is back in stock. I'm planning on building a head and a 2x12 cabinet. I've read that in order to take full advantage of the output transformers, the speakers should be 16 ohms. Is there a noticeable difference in these amps if the speakers are wired as 16 ohm vs 8 ohm (series vs parallel wiring I believe it's called.) I'm trying to understand whether not there are advantages or disadvantages to either speaker wiring setup with this amp. papa's scooperia
If you use 16 Ohm (Series Connection)
[list=]Optimal for sound and performance.
Reduces stress on the output transformer, prolonging its life.[/list]
