It is currently Tue Dec 02, 2025 9:52 pm
PostPosted: Wed Oct 04, 2006 6:18 pm
Hey guys, do you have info on providing a line out for direct recording and is it practical? The reason I ask is that when i eventually build an 18 watter, i'd love to mic' it with an sm57 while also recording direct by running it through a speaker cab sim and then into the PC. There are ideas floating around on the 18 watt forum but i was interested with reference to your designs.
Anyway, just a thought!
Have you guys finalized a date/time when the 18 watter kits with 6v6's will be able to ship?
PostPosted: Wed Oct 04, 2006 6:48 pm
There's no reason that the line out on the Lightning wouldn't work.
http://www.trinityamps.com/ForumGallery ... t_rev2.JPG
LeeMo
PostPosted: Wed Oct 04, 2006 8:09 pm
Agree with LeeMo. Two resistors will do just fine!
PostPosted: Wed Oct 04, 2006 8:13 pm
Actually soon we think. Could do now.
Would you want to have both EL84/6V6? Switching power tubes 'on the fly' is becoming a stubborn problem (POPping). If you use a toggle switch and need to switch it only periodically, I'd say, good to go.
If you only want 6V6 9no EL84), good to go!
PostPosted: Wed Oct 04, 2006 11:16 pm
Switching on the fly is not that big of a deal for me.. i'd be happy with a switch. But then again i'd also be happier with a switch between EL34's and 6v6's! haha. But i don't think that is an option. Primarily i'd be looking to the 6V6's for my power . You've got some time to finalize things though, i am still budgeting for a head kit and am almost there. Looking to put an order in within the next month or so. Early christmas/birthday combined for myself type thing.
PostPosted: Thu Oct 05, 2006 4:09 pm
Oh yes it is! :D That's what coco's sIII v6 build was all about! Both sets of tubes!
PostPosted: Fri Oct 06, 2006 12:52 am
:shock: Man alive are you kidding me? So it can operate with either EL34's or 6v6's? Or are they biased so that the 4 output tubes run together at the same time? I suppose its jus a matter if a bias switch and you are off to the races as long as the right set are in place.
That's awesome.. i think you guys have pretty much sold me on that right there. So do you expecct that within a month you'll be able to provide a kit that does this?
PostPosted: Fri Oct 06, 2006 7:11 am
:shock: Man alive are you kidding me? So it can operate with either EL34's or 6v6's? Or are they biased so that the 4 output tubes run together at the same time? I suppose its just a matter if a bias switch and you are off to the races as long as the right set are in place.
That's awesome.. i think you guys have pretty much sold me on that right there. So do you expect that within a month you'll be able to provide a kit that does this?
That's correct, switchable tubes using the same Output transformer. Shoot me an email.
PostPosted: Mon Oct 09, 2006 9:40 am
coco, did you get my pm?
PostPosted: Mon Oct 09, 2006 9:44 am
yes and responsed to ppolenton at hotmail dot com
 Post subject: Hmmmm?
PostPosted: Sat Oct 14, 2006 12:35 pm
Do you guys mean EL-34 or EL-84. Coco? have you been holding out on me?
PostPosted: Sat Oct 14, 2006 3:58 pm
LOL - we're talking EL84s, but come to think of it...anthing is a possibility..
