It is currently Tue Jul 16, 2024 12:42 pm
Post new topic Reply to topic  [ 182 posts ]  Go to page 1, 2, 3, 4, 5 ... 10  Next
 Post subject: New sIII build
PostPosted: Sat Jan 20, 2007 3:34 pm
Question number 1:
The turrets are definately larger then I drilled for. What size drill bit?
Yes, I still prefer building my own, cause I'm having fun :D and that's the name of the game. :lol:
PostPosted: Sat Jan 20, 2007 5:19 pm
Use a 5/32" drill bit for those turrets.
PostPosted: Sat Jan 20, 2007 5:26 pm
thank you
PostPosted: Sat Jan 20, 2007 7:43 pm
Good thing you didn't drill 'em too big!
PostPosted: Sat Jan 20, 2007 9:44 pm
Those Keystones are big 'uns. I am trying some new ones now that require smaller holes.
PostPosted: Sun Jan 21, 2007 11:16 am
After thinking about it, while reading your booklet (read first a few times, build after), I decided to save my first board for another project and use the new board I got from you. I learned alot from the first board. The second one will be better because of that. And what the hey, get that nice red swirl for the more authentic look :D
PostPosted: Sun Jan 21, 2007 2:11 pm
Next:
There's only three standoffs? 4 screws, but only 3 standoffs. Oops :lol:
PostPosted: Sun Jan 21, 2007 3:26 pm
I did It :D this board drilled perfect. Fit right in the holes on the chassis, much better then the first one. Although my next board I have to figure out how to get a cleaner cut. Maybe I'm using the wrong bit's. It is brand new though.
What kind of drill bits do everyone else use, I'm using titanium.
PostPosted: Sun Jan 21, 2007 3:29 pm
I am taking pics of the whole process, as soon as I figure out how to post on the web space Verizon gives me. The I'll post them.
Having a ball :D Do not care how long it takes, this is so much fun. And your booklet is great, coco.
PostPosted: Sun Jan 21, 2007 3:33 pm
Like wood, you should back up the exit side of the hole to get as clean a cut as possible when drilling.
Glad you're having fun.. all you have to do is copy the link (URL) from Verizon and paste it here. Then put on either end of the URL.
PostPosted: Tue Jan 23, 2007 7:59 am
Can't find the thread for the sIII boost, someone lead me there please
Thanks, Jac
PostPosted: Tue Jan 23, 2007 1:06 pm
viewtopic.php?t=657&start=0&postdays=0&postorder=asc&highlight=
How's it comin' so far? Burned your fingers yet? Let any smoke out of the components? :shock:
Just kidin'. :lol:
I know that you're having a blast. Take your time and savour the flavour.
LeeMo
PostPosted: Tue Jan 23, 2007 1:53 pm
Thanks LeeMo,
You've disaperred. That was the page I was looking for. Hopefully it'll tell me the voltage I need for the boost.
Yes, I've burned my fingers already. and havin' a blast doin' it.
Can't wait till it's done.
Trinity Rules! :D
PostPosted: Tue Jan 23, 2007 2:12 pm
Hot Rod Post:
viewtopic.php?t=657&highlight=boost
PostPosted: Thu Jan 25, 2007 8:23 am
The boards done :D
I know, I know, have to get the pics up :lol:
PostPosted: Fri Jan 26, 2007 1:34 pm
Suggestion:
There is a black "film" on the chassis. I imagine it's from the aluminum being protected.
If the machine person happens to know of a way to get all of it off that would be great. The only way to not scar the surface and take it off , is with your nails. Very time consuming.
Not b**ching, just be easier to not have to do. Just go right to polishing.
Jac
p.s And yes I do everything and have a ball.
I'm a geek. Thats why I'm here, only the best.
:D
PostPosted: Fri Jan 26, 2007 2:01 pm
I'll look into that. Not had a problem with it tho..
PostPosted: Fri Jan 26, 2007 2:33 pm
Again, I wasn't complaining, I'm just trying for the perfect amp. Might not look as great as others, but it's mine.
The "rubber" was just hard to scrape off. That's all. I thought just for someone else.
Althoough I still intend on buying the lightening :shock: :D
Jac
:lol: Wait, that came out totally wrong :lol: It's no problem with me, just thought I'd mention it for you.
Man, I can't talk righht anymore.
Jac
PostPosted: Sat Jan 27, 2007 11:56 am
Okay, let's see if this works. Set up photosite for build pics. Still have to upload more and sort them in order.
http://new.photos.yahoo.com/all_photos? ... ge_count=8
I'll be, it actually worked.
Wiring up the power section now :D and I now am up to three bandaids :shock:
PostPosted: Sat Jan 27, 2007 2:04 pm
Well, I'm definately finding out that it's much harder to wire a combo then a head. there's just no room for fingers or errors :shock:
