It is currently Mon Aug 24, 2026 12:36 am
PostPosted: Mon Apr 03, 2017 10:23 pm
I'm sure this has been done many times by users here.
I'm in the experimenting phase and my interest here is not to include a presence control but simply add the feedback resistor and shunt resistor to the appropriate point on the LTPPI with feedback taken from the 8ohm secondary tap. If it was just a TMB circuit then I'm pretty sure I know what to do (courtesy of Merlins book). However, the normal channel feeds into this as well, and that has me a scratching my head. Has anyone created a schematic for this?
Thanks in advance ...Dave
PostPosted: Mon Apr 17, 2017 9:11 am
Yes, it has been done. Take a look at thisschematic. It was prepared by unimind http://www.unimind.us/images/Trinity18_ ... ematic.jpg
PostPosted: Wed Mar 11, 2026 4:28 am
In a typical single-channel TMB circuit, the negative feedback is usually taken from the 8-ohm secondary tap of the output transformer and Melon Playground Game returned to the phase inverter tail or cathode network. However, when a normal channel is mixed into the circuit, the signal paths interact before reaching the phase inverter, which can make the feedback connection less obvious.
