It is currently Tue Dec 02, 2025 8:29 pm
 Post subject: Optimal? Attenuator
PostPosted: Thu Jul 12, 2007 8:25 pm
I know attenuators have been covered a lot so sorry about another question on them.
I've been trying the suggestions for finding your tone from the Trinity Amps Mag.
The amp sounds great :D
I'm rattling parts of the house :oops:
I've seen the threads on the L pads and the resistor switch ideas. My question is for anyone who has tried them both, or any additional ideas, what works the best? Reasonable attenuation with minimal loss of tone is what I mean.
Then, can you guide me to where a simple guy like me can find a layout and instructions on how to add it to my SIIIv6?
Thanks everyone :D
PostPosted: Fri Jul 13, 2007 10:11 am
I built the one attenuator, want me to send you pics?
Also, I have the ultimate attenuator that flew thu 18watt. I can send the schemo and pics. Very cool.
:D :D
PostPosted: Fri Jul 13, 2007 10:24 am
That would be great :D
Please send me what you have.
What is your opinion, which works "better"?
Are they easy to build and install?
Thanks!!
PostPosted: Fri Jul 13, 2007 10:36 am
Only built the 1. But you can get all the parts at Radioshack :shock: Go figure. Not expensive, either.
The other one I haven't built yet, But I will. Very cool. Send them in a little while.
:D
PostPosted: Fri Jul 13, 2007 8:06 pm
Here's the cheap'o attenuator I built:
Mostly used for High Octane(5W) with 6V6 tube.
Also used for Spitfire (15W) clone, runs quite hot at full 15W tube power
but should be ok. 4 ohm only.
High Octane with attenuator
http://home.online.no/~eber-ha/TubeAMP/ ... 65SD_1.mp3
High Octane without attenutaor
http://home.online.no/~eber-ha/TubeAMP/ ... _NO_A2.mp3
I actually prefer playing the amp with the attenuator
since it cuts of the high freq. a bit. (and saves my ears)
My High Octane has a small Fender Champ transformer which is very
bright,and the Spifire is also bright if you run it at full power distortion
with EL84. So it suits my needs at the moment.
Could be used for the 18 watt also but maybe some
higher watt resistors(+5W).
Espen
PostPosted: Fri Jul 13, 2007 8:28 pm
Thanks Espen :D
It looks like the lead from the amp jack connects to the pole of switch 2 at the speaker jack (my monitor cuts it off a bit). Is that correct?
I appreciate the help!!
PostPosted: Mon Jul 16, 2007 4:39 pm
That is correct, its just a simple bypass of the attenuator.
Here's a simple calculator for the values:
http://www.lalena.com/audio/calculator/lpad/
or
http://www.webervst.com/lpad.htm
Espen
PostPosted: Tue Jul 17, 2007 5:45 pm
Espen, thank you for all of the help, the reference sites are great :D :D :D
Users browsing this forum: Google [Bot] and 33 guests
