It is currently Tue Jul 16, 2024 5:01 am
PostPosted: Sat Jul 09, 2005 10:32 am
So, I'm thinking, you could get the 30 watt transformers, how difficuilt would it be to put in to EL34's instead of EL84's? Or a 4-pack of EL84's?
PostPosted: Sat Jul 09, 2005 12:40 pm
Pretty straightforward, especially with the 4-EL84. Some output config as the DC-30.
PostPosted: Sat Jul 09, 2005 6:44 pm
Any cap value changes or resistor value changes, or could I bump up and get the 30 watt trannies and just add two power tubes?
PostPosted: Sat Jul 09, 2005 7:45 pm
Go to this thread:
viewtopic.php?t=45
Check out the DC-30 schematic and Output stage.
PostPosted: Sat Jul 09, 2005 8:19 pm
has anyone actually built this DC30 clone yet?
What about dropping a pair of EL34's into the existing LIghtning with some 30 watt matchless trannies?
PostPosted: Sun Jul 10, 2005 9:15 am
No one has built that version. In fact the layout is not correct. It's just posted in case someone wanted to take up the torch and try it. I believe that the schematic is good.
I'm not sure if the B+ voltage is high enough :?: but theoretically, you could put EL34's into the Lightning with 30 watt transformers. However, it would not sound like a 30W Lightning or DC-30. The EL84 have a real sound/chime to them. It's interesting to note that Vox dropped 2-EL34's in the early AC-30 in favour of 4-EL84, just to get that chime.
PostPosted: Sun Jul 10, 2005 9:17 am
This topic was moved to the more appropriate 30Watt EF-86 forum.
PostPosted: Tue Jul 12, 2005 8:09 pm
AC50s and AC100s still have a recognizable "Voxy" character even with EL34s.
PostPosted: Wed Jul 13, 2005 8:29 am
True, but Vox did switch to 4-EL84's from 2-EL34s in the AC-30. I guess it's hard to beat that chimey EL84 sound in a low watt design.
