It is currently Fri Jan 16, 2026 6:35 am
PostPosted: Sat Jun 02, 2007 10:53 am
Please let me know your thoughts. I'm putting it in a 17" X 6" chassis box. The order of the parts from left to right (not including transformers) is:
rectifier, cap can, el84 X 4, 12AX7 X 3
I'll be using the layout for the 36W
PostPosted: Sat Jun 02, 2007 10:59 pm
Wouldn't it give you more room if you placed the capacitor between the trannies in front of @ V6 and V7. Haven't seen a 36 watt layout but just seems to be an easier placement. Push the OT to the right just a hair to accommodate the change.
And when you finish, Could I have a copy please :D
Later
PostPosted: Sun Jun 03, 2007 12:19 am
Like this?
viewtopic.php?t=752&start=0&postdays=0&postorder=asc&highlight=
First picture.
I see nothing wrong with your layout tho.
LeeMo
PostPosted: Sun Jun 03, 2007 12:36 am
I didn't say there was anything wrong, I just think it's a easier to build layout with the cap between.
And yes your link was what I was implying. Thanks Leemo.Always on the ball as usual. :D
PostPosted: Sun Jun 03, 2007 7:38 am
Thanks for the input guys. I think that might be a really good idea, but I made the turret board yesterday and there will not be much room between it and the PT. I will have to look at this idea a little closer.
It is a very good point. I'm thinking that if I do this, it will give me more room for the power plug and I won't have to route the along the side, and I can go straight to the PT.
PostPosted: Mon Jun 04, 2007 12:54 pm
BTW, make sure the PT & OT axis are at right angles to each other. I'd move the cap out of the line-up as well.
