It is currently Thu Apr 23, 2026 4:37 am
PostPosted: Wed Feb 20, 2008 12:06 am
While it seems pretty natural to me, preparing co-ax cable can be a challenge. I hope this helps.
Plain Co-Ax cable
Strip about 3/4" outside insulator off on end and 1/2" off other end
Push metal braided sheath towards one end so it bulges out
Use a large needle or small jewller's screwdriver to poke a hole
through the bulging sheath and 'fish' enough so you can get pliers to grip the inside conductor
Use needle nose pliers to grip and pull the inside conductor through the hole you just made
Twist the braid into one strand and strip 1/4" off the inside conductor.
After you've prepared the oposite end, apply 1/2" of shrink tubing over the end of the cable.
PostPosted: Wed Feb 20, 2008 8:29 am
Good one, coco! I had some fun trying to separate that braid until you told me this method!
JP
PostPosted: Thu Mar 27, 2008 5:03 pm
Now why didn't you do this before.
I would sit there and take apart every strand for about an hour.
Damn :D :D :D
PostPosted: Fri Mar 28, 2008 1:22 pm
sorry :oops:
PostPosted: Thu Apr 03, 2008 7:30 am
Greetings all.
Is there a need for more of these sorts of wiring/building "Tips" on this forum? I can see that many of you are seasoned builders, but I can also see many questions being asked by others who are first time builders and could probably use a bit of advice to get started on the right foot. I don't want to step on any toes (especially with the boss), but I would be more than willing to offer tips and maybe photo examples like Stephen had here on various soldering and wire servicing procedures. I'm a 25 year veteran of the defense industry with DOD, NASA and J-STD 001 certifications. I'm titled as a Master Technician/Engineering Assistant with a specialty in wiring and cabling for NG and formally with UTC. Please let me know if this sort of information would be helpful to anyone.
 Post subject: re: Tips
PostPosted: Thu Apr 03, 2008 5:24 pm
Hi Joe,
I'm about to embark on my first build (Plexi/V6). I would be grateful for any information/tips you could provide on soldering, tinning and prepping wires.
Mark
Mark
PostPosted: Thu Apr 03, 2008 8:32 pm
joeyvelour wrote:
Greetings all.
Joe,
Sorry I missed your post!! :oops:
Great Offer!!! Absolutely, anything you want to do would be very much appreciated & we can help if you need some for posting/hosting your pictures..
PostPosted: Fri Apr 04, 2008 9:44 am
Thank you for the great reception and I'm more than happy to help if I can!
Stephen/everyone... What do you think would be the most useful format for something like this? There is a lot of information, and it would be great if it were all in one, easily accessible place that didn't get lost in the archives of the forum over time. Should it broken down into separate tutorials that correspond with the typical build, such as "Tool Selection", "Solder Types/Selection and Why", "Basic Mechanical Assembly", "Standards for Specific Solder Terminals", "How Getting Killed While Building a Guitar Amp Can Ruin Your Whole Day!!!", etc.?? Pictures seem to tell the story best, if not video. I would definitely need suggestions for posting pictures and so forth. Of course, I could always ask my 14 year old daughter for that info!!!
Thank you all in advance for your input!
PostPosted: Fri Apr 04, 2008 10:31 am
We can make them "Stickies" so they're always up front or Add a new Resources forum.
Any thoughts?
PostPosted: Fri Apr 04, 2008 11:07 am
Actually, I was inspired to create a resources forum. It is only visible to forum members and will need an active moderator or two, or 3.
PostPosted: Fri Apr 04, 2008 11:09 am
I think a new "How To" Forum, might be the trick, with individual "How to's" for those challenging tasks as individual Topics.
JP
PostPosted: Fri Apr 04, 2008 12:03 pm
As a future project... How about a "How To" DVD, either enclosed with or offered for your kits? I'm on the edge of starting a build. Should I film it??? I love making a major production with everything I do... Just ask my wife!
PostPosted: Fri Apr 04, 2008 8:19 pm
Sounds very ambitious. It would have to be quite general in nature though because the design changes, there are variants and different amps , but a general good idea. Could stream it from the web site.
PostPosted: Sat Apr 05, 2008 3:59 am
Hi all,
I think at this point a "How to" forum is the way to go.
Place it right at the beginning so all "newbies" (and me too!) will automatically see the info.
Joe:
Glad to have you onboard.
If I didn't say it before, glad to be back all.
Trinity amps are the worlds easiest to build and best sounding.
As usual, my 2 cents.
Later.
PostPosted: Sat Apr 05, 2008 12:39 pm
I think Stephen is right about the video idea as far as taping an entire amp building project. Perhaps just quickie videos of the common steps, such as stripping and tinning wires, lead forming, soldering to a turret terminal, that sort of thing to supplement some still pics and text. It would be just enough to give people the tools they need, but not push the limits of their attention span. I just sat through a 5 day certification for J-STD soldering, including 2 days of pathetic soldering videos from the 80's. We should make the terrorists sit through this stuff!
I've already started outlining some "Getting Started" information on proper tools, choosing the correct solder, that sort of stuff. Any suggestions on a format would be appreciated. I can submit perhaps Word™ docs to Stephen for editing an/or commentary, whatever works. I'm a decent musician, but not a big computer guy. Let me know.
Thank you again for the welcome reception. I hope my info will help out!
PostPosted: Sat Apr 05, 2008 2:32 pm
Word is fine, including pics. I can move into the forum as/if required. The format of the forum does not allow for great formatting but let's try! If necessary, we can create web pages for each subject but having it as part of the forum is a little more convenient. So, only advice I can offer is to keep it simple!
I like the idea of little "movie" snippets as you suggested.
PostPosted: Wed Jun 22, 2011 7:38 pm
How is this procedure working for people?
PostPosted: Wed Aug 03, 2011 1:21 pm
I haven't tried it yet, but then again, I just read it. Thanks for the tip!
PostPosted: Thu Aug 11, 2011 6:15 pm
My asumption was that the operation in all the original pics was to create a shield "wire" for the purpose of soldering it. This is what I assumed was in the first picture above. If that's the case, is the second picture supposed to be of the opposite side of the coax cable, showing how the braid is protected by the heat shrink? Or, is it the intent to show how you can REALLY move the heat shrink back if you follow all of the original operation pics and then snip off the braid before covering it with heat shrink?
I suppose it comes down to what you mean by "prepared" for the other end.
PostPosted: Thu Aug 11, 2011 7:05 pm
The shield should only be connected to ground at one end of the cable.....typically at the jack or pot. The shrink tubing covers the exposed shield wires at the opposite end to prevent anything from contacting them & shorting to ground.
** b0b0 **
- This Space For Rent -
