It is currently Tue Jul 16, 2024 4:23 pm
 Post subject: Power transformer 5V tap
PostPosted: Tue May 06, 2008 11:48 am
Is there any problem with using the 5V tap on the PT to power a LED that I want to use on a switch? I figure there is no problem, but just wanted to make sure.
PostPosted: Tue May 06, 2008 3:45 pm
No problem, be sure to rectify & filter it tho and add an appropriate dropping resistor in series with it.
PostPosted: Tue May 06, 2008 7:45 pm
Would there be another spot already on the amp that is filtered and rectified to take some juice from, or am I better off just doing it separate?
PostPosted: Tue May 06, 2008 8:24 pm
Most are pretty high voltages so just tap pf the 5V.
