It is currently Sun Aug 23, 2026 6:50 pm
PostPosted: Tue May 13, 2008 3:03 pm
Does any one know what the material is under the filter capacitors on a DC 30.
Ian
PostPosted: Tue May 13, 2008 7:15 pm
Sorry, no idea.
PostPosted: Mon Aug 22, 2011 8:26 pm
Old thread but I'm looking for ideas on a 30watt/EL84 build. I recently built a Hotcat clone and when it came to working out what the material was under the caps I thought it was some form of thin padding material (duh) I bought some pure rubber sheet that was expensive and stank but ended up shortening a family members yoga mat! 10 bucks and you get metres of brightly covered neoprene about 3mm 0.12inches thick.
http://i188.photobucket.com/albums/z265 ... ages-1.jpg
PostPosted: Mon Aug 22, 2011 8:31 pm
Looks like a foam cushion of some sort
PostPosted: Mon Aug 22, 2011 9:57 pm
Sorry I should have said this is a picture of my Badcat clone which is pretty much the same as the Matchless builds? The purple stuff under the filter caps is the yoga mat I pinched. It is just a cushion and it's all held together with non conductive silicone.
