It is currently Mon May 25, 2026 4:18 pm
 Post subject: switchcraft input jacks
PostPosted: Mon Aug 18, 2008 5:50 pm
Do matchless use a fibre washer to insulate the switchcraft input jacks from the chassis because they run a ground wire to the input jack
PostPosted: Mon Aug 18, 2008 7:32 pm
I guess if they run a ground wire, they must be isolated otherwise there could be a ground loop problem.
