It is currently Tue Jul 16, 2024 5:55 pm
 Post subject: New Build
PostPosted: Wed Aug 20, 2008 9:53 am
Hi my first build (newbie) :roll:
lots of humming with cable (1/4" instrument no guitar) in
none removed
not much gain more of a good crunch and muddy and or sloppy at high volumes
would appreciate any thoughts and or tips
thanks in advance
PostPosted: Wed Aug 20, 2008 12:24 pm
Is C2 tied to the tag board mounting bolt? It looks like the other side of C2 could potentially hit the mounting bolt on that side as well. Which layout did you build to?
Joe G
Some assembly required,
Brain sold separately...
PostPosted: Wed Aug 20, 2008 4:56 pm
lots of humming with cable (1/4" instrument no guitar) in but none when removed
usually means a cable or equipment problem. What happens when the guitar is also plugged in. An open end makes a great antenna.
Not much gain more of a good crunch and muddy and or sloppy at high volumes.
build to design and lets go from there. the grid stopper is off V2 on the build
 Post subject: getting better
PostPosted: Wed Aug 20, 2008 11:50 pm
Joe G
Hi
must be optical illusion C2 not tied to bolts on either side
Using the layout sent with kit Rev 4 dated 1-8-08
 Post subject: Getting better
PostPosted: Thu Aug 21, 2008 12:10 am
Checked layout (found some errors :oops: ) took advise and replaced grid stopper and things are sounding quiet.Still fizzy and muddy past 2....
using Strat w/singles Vol 4 Gain 8 T 4 M 2 B 8.....
will continue tweaking any suggestions are extremely welcome
PostPosted: Thu Aug 21, 2008 7:33 am
How does the normal channel sound?
PostPosted: Thu Aug 21, 2008 3:44 pm
Sounds good except past 3 or 4 it gets fizzy and muddy
PostPosted: Thu Aug 21, 2008 4:36 pm
Time for a voltage check. Can you post the voltages please?
PostPosted: Thu Aug 21, 2008 10:50 pm
Here goes :shock:
V1
1-152
3-.84
6-148
8-.92
V2
1-144
2-.008 ?
3-.96
6-260
7-144
8-144
V3
1-210
3-70.4
6-205
7-47.9
8-70.4
V4
3-11.5
7-339
9-327
V5
3-11.5
7-337
9-326
V6
1-308
3-349
7-308
Some dont seem to look right
I triple checked
so let me know
thanks
PostPosted: Sun Aug 31, 2008 2:03 am
:D This is a great kit and has got me hooked on tweaking and researching
stuff I really enjoy.Slowly but surely I am learning the ins and outs
Thanks to Stephen for a great classic sounding amp.
With that...
I think I got most of the problems worked out
Flabby fuzziness gone(change of speaker :oops: )
Sweet clean sounds with the strat really nice tones from normal channel.that sparkly sortof overdrive TMB channel SRV kinda tones
really nice too.
Humbuckers....well... my LP and Jackson...well I guess I need help
tone just isnt there overdrive and or distortion just not happening
did most if not all gain mods to no avail.... :(
any comments or suggestions would be greatly appreciated
PostPosted: Sun Aug 31, 2008 3:07 am
if it sound good with singles, and not with humbuckers, id mess with the input impedance, at least, its what i do with pedals (higher=brighter so i guess here is the same ;-)
PostPosted: Sun Aug 31, 2008 8:06 am
IMO, the TMB has plenty of gain/overdrive.
1. try 12AX7 tube[s] with a reputation for higher gain
2. Jump channels
3. add 25 uf across R9, cathode bias for V2.
4. plug into Hi Input; vol on 10 on guitar
5. change input impedance [in the manual]
PostPosted: Sun Aug 31, 2008 10:14 pm
2. Jump channels
thanks applied all of these and cranked it :shock: Holy Crap
sounds great (LOUD) with LP and Jackson HB's:D
If available wondering if the VRM mod would help my family's ears
and recording...
(I need to feel the notes as I play :lol:)
I'm still going to experiment with the low end sorta muddy for lead notes
got a buddy with a wood shop helping me put together head a speaker cabs... said he has some mahogany .
Saw pics of cabs elegy made and will model after those(they look very nice)
PostPosted: Sun Aug 31, 2008 11:15 pm
definately go for the vvr, i installed mine without much expectations and now i can play at home :D
PostPosted: Mon Sep 01, 2008 9:07 am
Try a 25uF/50V on the power cathode bypass cap instead of 220 like elegy did.
PostPosted: Mon Sep 01, 2008 10:33 pm
hi guys
tubes matter just changed all pre amp to jj's and sounds much better...
at 8 vol 9 gain
Coco
I will order a cap and try this(replaces the 220uF/50v ?)
I would like to try the vvr also I did not see them on your website for sale
let me know if I can purchase.
PostPosted: Fri Sep 19, 2008 10:17 am
Any suggestions for the boost hole on the back chassis of my TMB build
any switchable mods or such?
PostPosted: Fri Sep 19, 2008 12:11 pm
Greetings 1412!
The schematics and layout drawings for the sIII, V6 and Plexi (in the Resources section) each show the implementation of a hard switchable boost.
If you're feeling really adventurous you may try the "soft boost" circuit shown here...
viewtopic.php?t=1093
Hope that helped...
Joe G
PostPosted: Sat Sep 20, 2008 11:09 am
did the simple hard switch
not sure about the soft switch looks a little too adventurous
I may be done tweaking(will be adding VRM soon)
I think I need to get it in a cab. :D
