It is currently Wed Jul 17, 2024 7:35 am
PostPosted: Fri Aug 29, 2008 5:25 pm
I seem to have gotten a 2M resistor in place of a 2.2M and 5W/120 instead of a 10W/120.
Will I have any problems using these parts instead of the ones shown on the layout?
Thanks in advance. :D :D
PostPosted: Fri Aug 29, 2008 5:43 pm
No. You should be fine. Both are what is sent with the kit. Need to update the BOM. :oops:
PostPosted: Fri Aug 29, 2008 6:19 pm
Thanks for the quick response.
Is the "boost" hole for the "crunch munch" switch or is it seperate?
PostPosted: Fri Aug 29, 2008 8:49 pm
In the TC-15 Boost hole is used for an extra gain switch for Ch. 2. Crunch munch goes in the hole between impedance switch and mains IEC connector. New head chassis now have a third hole for even more options.
PostPosted: Sat Aug 30, 2008 8:03 am
Is there a diagram on the Forum to show thw wiring of the boost switch? I tried to locate one but didn't have any luck. :(
Also, there are no holes in the chassis for the mounting of the tag strips for the ef86 tube and the 12ax7 in V1. I this correct?
Thanks, Chuck
PostPosted: Sat Aug 30, 2008 8:45 am
Here is a solution to mod the board if necessary: viewtopic.php?p=11619#11619
Yes, use the socket mounting bolts to hold them in place.
PostPosted: Sat Aug 30, 2008 10:28 am
Thanks Coco,
I looked in the TC15 documents and must have just pass over it completly. :oops:
Regards, Chuck
PostPosted: Sat Aug 30, 2008 11:20 am
Nope. I just posted them this morning!
PostPosted: Sat Aug 30, 2008 4:51 pm
Well that explains it then. I thought after following your link Coco, how could I have missed that? :?
Chuck
