It is currently Tue Dec 02, 2025 3:23 pm
PostPosted: Mon Jun 20, 2005 5:07 pm
Westlabs sells those three-way switches. I plan on wiriing my Lightning up with a 3-way for a standby position. Anyone else do this?
A basic question.... why no standby in the default configuration?
PostPosted: Mon Jun 20, 2005 7:59 pm
That would be cool with two pilot lights like a Vox Cambridge Reverb.
PostPosted: Mon Jun 20, 2005 8:38 pm
I did that with the tremolo lightning I just finished, I used a progressive circuit switch from Mouser, but it does the same thing as the one from west lab (and I think the west lab one is cheaper). IT works very well, especially for running different rectifier tubes that don’t have the delay time of the GZ34/5AR4. :lol:
Eddie
PostPosted: Tue Jun 21, 2005 6:39 am
The stock GZ34/5AR4 rectifier has a built in delay so it wasn't necessary.
PostPosted: Tue Jun 21, 2005 1:57 pm
I don't believe the progressive switches like Westlabs sells (don't know about the ones from Mouser) have poles enough to handle lamps. I've done a couple with two lamps, one with two DPDT toggles:
http://www.18watt.com/modules.php?set_a ... _photo.php
and one with a rotary switch:
In both cases I used 120-volt neons from Radio Shack, but the switches would work for 6.3-volt lamps as well.
PostPosted: Tue Jun 21, 2005 6:19 pm
are you saying that all amps with 5AR4's do not need standby switches? I honestly had no idea that was the case. damn, learn something new every day! :)
PostPosted: Tue Jun 21, 2005 7:55 pm
Yup. But some people like to put one in anyway! :wink:
And if I was going to, I'd use the West Labs switch. 8)
PostPosted: Tue Jun 21, 2005 11:23 pm
The tube (GZ34) has a fairly slow start up time...giving the other tubes ample time to warm up before seeing any action...
PostPosted: Tue Jul 05, 2005 11:11 pm
Most rectifiers give ample delay to avoid the need for standby switches. The only rectifier I can think of is the 5U4 which can actually benefit from a standby (not that it really needs one, but it can help extend tube life slightly). Otherwise, you need to hit the realm of 700VDC+ before you have to worry about cathode stripping and that only happens in hi-fi amps.
So in reality, standby switches serve 2 purposes:
1. Maketing mumbo jumbo hype stuff
2. An avenue for keeping your amp warm between sets if you really wanna.
--s2
www.s2amps.com
www.category5amps.com
PostPosted: Wed Jul 06, 2005 1:37 am
There's an interesting discussion on standby switching at http://ozvalveamps.elands.com/standby.htm
Lots of other useful info on the site too, especially if you're into vintage australian amps :D
Cheers,
Rick.
PostPosted: Wed Jul 06, 2005 8:35 am
good link
