Friend |
Joined: Thu Oct 30, 2008 8:16 pm Posts: 16 Location: London, Ontario
Hi Richard,
Thanks for responding.
For channel switching I use an A/B/Y box on the input, but this happens even when I'm not using my A/B/Y switch. For example when I plug the guitar directly into channel 1 and turn the volume up on the T/M/B drive channel the treble is cut down on channel 1.
At one point I removed the 500pf cap on the volume control to reduce that channel's bite, but now I'm thinking of putting it back in (switchable) to compensate.
Is there was something else I should be doing ??
cheers,
Brian
