It is currently Fri Dec 05, 2025 10:26 pm
 Post subject: TRIWATT Board Build
PostPosted: Tue Mar 24, 2009 9:04 pm
First TRIWATT Board built by Forum Member "kurtlives" for Trinity Amps
PostPosted: Wed Mar 25, 2009 9:44 am
That thing is hot
Love the right angles, really gives it a clean, pro look.
PostPosted: Wed Mar 25, 2009 11:25 am
Thanks man. Meant to have that hiwatt'ish look as well.
PostPosted: Wed Mar 25, 2009 12:18 pm
What are you using for the post to post connector wire?
Looks to be "slightly" thicker than the component lead diameter.
Looking forward to the kit :D :D :D
PostPosted: Wed Mar 25, 2009 2:00 pm
It's 20 Gauge solid copper tinned wire.
PostPosted: Wed Mar 25, 2009 3:30 pm
looks like it's be cake to work on. :)
PostPosted: Wed Mar 25, 2009 8:09 pm
what are those 4 black resistors with silver bands on the end??? ;) The horror!!
AJC
PostPosted: Wed Mar 25, 2009 8:22 pm
AJC
Actually, there's 5!!! :)
PostPosted: Wed Mar 25, 2009 9:38 pm
They're 1W Metal film for low noise. For values >= 100K
PostPosted: Wed Mar 25, 2009 9:50 pm
I was referring to the diodes... :)
You guys are slow! ;)
AJC
PostPosted: Wed Mar 25, 2009 10:21 pm
So was I...there's 5 diodes dude! :D
Looks like your kit will be ready for pick-up. Chassis arrive tomorrow!
PostPosted: Wed Mar 25, 2009 10:29 pm
OK then, just Stephen is slow... :)
AJC
PostPosted: Wed Mar 25, 2009 10:45 pm
You guys go ahead and count 5 diodes. I'm counting 500! :P
PostPosted: Sat Mar 28, 2009 10:01 pm
For those folks who're into "resistor spotting", the smaller resistors on the board are 1W metal films, used where noise is more likely to be an issue. Most of the rest are 1W carbon film, to add some general warmth. The PI's two load resistors are carbon composition to bring a hint of sweetness into that otherwise, tough-sounding Hiwatt tone. The PI load resistors are the one place in the amp where the non-linear characteristics of carbon comp resistors have the most beneficial effect on the tone, while contributing the least to overall noise levels. Like I mentioned before the TRIWATT has the same number of gain stages as a SLO or Mezza DR, and so we have to chose components particularly carefully.
PostPosted: Sun Mar 29, 2009 2:37 pm
Ya know Phil, it's amusing to hear you discuss, lovingly, about carbon comps :lol: :lol:
I have sent the extra money I owed for this amp. I will build this right. Well, I'm having some genetic help.
I believe this is the best design I've ever seen.
I mean comon', take a Hiwatt and make it none ear blowing. 8) 8) 8)
I retract every statement made, that I ever said .
I can't wait for the amp to arrive.
It's an amazing accomplishment
CONGRATULATIONS!
