Thank you both for the guidance and info + links. I absolutely LOVED that TC-15 with the Tone Tubby Alnico. - Definitely articulate, not muddy.
Coco: you said,
There are so many variables. You can brighten up the amp with Tung-Sol 12AX7s, use Alnico speakers, change the guitar pick-up. It already has an EZ81 rectifier so maybe even SS rectifier etc.
This is the 18 you're referring to I guess? That's what's difficult for me, ajcoholic says it's the TC-15 I'm looking for, and I must admit, I am darn partial to Vox chime and jangle, but I've always found they lack a certain punch.
On the other hand, the 18 seems to have more grit - which is why I can't quite understand an amp like the London Soho by 65 amps. It's almost a MarVox, if there is such a thing?
I REALLY love the TC-15 DIRTY clip with the Tone Tubby Alnico, AND the
18 Watt v6 - 6V6 Dirty Tone Tubby Alnico equally. I think I'd like them both in a single cabinet - the perfect balance of grit and jangle. Or copy exactly what the Soho combo has: An Alnico blue, and a G12H 30.
This is exactly the setup I'd have:
• Gretsch jet, (strings 11's or 12's + wound G.
• TV Jones classics
• A single 2 X 12 with an Alnico blue and a G12H 30
• A trinity 18 or TC-15?
I heard an AC 15 in a music store about a year ago - a newer one. And I really did like the articulation it had, but it lacked punch. The mid range was a little weak. As much as I loved the tone overall, I thought, hmm, I don't see it having "Growl".
If you ran a tube based pre-amp before the TC-15, would that help beef up the mids? Or am I off on something else completely here? Should I just stick with an 18 with Coco's suggestions?
