It is currently Tue Dec 02, 2025 6:25 am
PostPosted: Thu Jul 07, 2005 1:32 am
Well, my OT has 4, 8 and 16 ohm taps. I can't really see myself using the line out feature.
Maybe I don't understand what it is fully capable of, but it seems rather limited with no real speaker emulation. Headphones late at night perhaps?
I think I'm just going to add the 16 ohm out instead of the Line Out.
What did you guys do?
PostPosted: Thu Jul 07, 2005 3:47 am
I don’t think you would want to use the line out for headphones unless you had one of the other taps run into a dummy load/line dump, since the line out does not provide a load for the OT. It is handy if you want to run another amp. The OT I used (s2) also has taps for 4, 8, & 16 ohms, so I just drilled another hole, well actually 2 since I added a level adjust to the line out. All that being said, I could defiantly live without it, but you never know.
Eddie
PostPosted: Thu Jul 07, 2005 10:46 am
No, don't use it for headphones. It is useful when you want to drive another amp or PA, or effect. The original amp has this, but go ahead and sub a 16 ohm if you prefer.
PostPosted: Sat Jul 09, 2005 8:27 am
I drill an extra hole in the chassis and use both options myself. I use the line out feature quite a bit in my little home studio to drive a Red Box. I also plug it into my Marshall for a Herzog effect. It's muy bueno!
--s2
www.s2amps.com
www.category5amps.com
PostPosted: Sat Jul 09, 2005 6:38 pm
Eddie
Is it me, or does that choke in the pic above look massive? What brand trannies did you use?
PostPosted: Sat Jul 09, 2005 6:51 pm
I got the transformer set (including the choke) from s2. The choke is a Hammond, don’t recall the value at the moment (I believe it is a 159M which is rated at 10 Henries, 100 mA), and the PT & OT are s2’s design. I have been very happy with the performance and sound of the set.
Eddie
PostPosted: Sat Jul 09, 2005 11:39 pm
If it's the choke that s2 provides, I think that's a 158M...
I'm obviously not there yet....but I'm not doing the seperate speaker outs.
I like the option of plugging into more than one speaker, so I'm going to do my outs like a traditional marshall...
I've got a 3-way switch that will give me 4-8-16 and I will have 2 parallel outputs wired hiwatt style for the extra insurance.
Then, I'm going to drill an extra hole for that line out....
Once I get this compressor pedal done, it's lightning city for me!!!!
