It is currently Thu Apr 10, 2025 1:07 am
Post new topic Reply to topic  [ 43 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun May 03, 2009 8:13 pm
Your soldering of the filter caps - looks a bit suspect. Doubt that is your issue, just throwing it out there.
PostPosted: Sun May 03, 2009 10:53 pm
Dont think thats it.
I am off to buy a cap, will report back.
Stephen, please do check the soldering f the vol pot, thanks.
www.paradisepi.com
 Post subject: More pics
PostPosted: Sun May 03, 2009 11:11 pm
More pics.
Bought JJ EL 84's, Tungsol 12ax7, EH ef86, and a sovtek 5AR4.
Also have a set of TAD EL84 to try out.
www.paradisepi.com
PostPosted: Sun May 03, 2009 11:49 pm
I know, I said that I didnt think it was a problem.
Merely saying it wasn't doing any good though. 8)
PostPosted: Mon May 04, 2009 4:19 am
Oh man 2 hours at local electronics market, and none had the right cap.
I did find a ceramic cap with the right specs, but those are not right?
They have silver mica caps with the right specifications at the BBQ shop, will those do.
@Kurtlives, no worries, appreciate your input anyway :D
www.paradisepi.com
PostPosted: Mon May 04, 2009 2:38 pm
Ceramic caps will work..some say they added "gridiness" to your sound, some say they are nosier than Silver Mica.
Then there are people so say Silver Mica are harsh, bright and non-musical :?
You can use any cap with the right value and voltage rating. I would use a Silver Mica in the end.
PostPosted: Mon May 04, 2009 7:45 pm
Cool thanks.
I did buy 1 ceramic......didn't ruin me anyway,. i will put that in until i get the micas.
Thanks.
Stephen, i would still like to know if i soldered the volume knob right.
www.paradisepi.com
 Post subject: Update
PostPosted: Wed May 06, 2009 10:02 pm
Ok, i've been searching for errors, and found a few.
Theres is sound in all channels.
But for all channels the sound is dull and distorted.
All the tubes are brand new, and i tried to swap output tubes, and preamp tubes, same result.
Also tried different speaker.....same same.
Anybody got a suggestion.
www.paradisepi.com
PostPosted: Thu May 07, 2009 10:39 pm
The Cathode resistor in this pic is way wrong. Looks like you swapped the 120 ohm 5W with 1K5 5W intended for the can cap. Please check that!
PostPosted: Thu May 07, 2009 10:42 pm
Master volume wiring looks fine. The Blue & Brown do go to different terminals, correct?
Let me know what parts you need & I'll send them over.
PostPosted: Thu May 07, 2009 10:47 pm
Looks like the polarity of the first 25uf electrolytic cap from the right side is reversed. Negative goes the other way. Please check.
PostPosted: Fri May 08, 2009 12:48 am
Thanks Stephen.
I spotted the reversed cap myself, but not the cathode resistor, and that did the trick, and the amp sounds great allthough i think it breaks up quite early.
I like the cut knob, makes it easy to dial in the right tone.
I will try and get the parts myself, if i can find them.
It's only those 3 resistors.
Unless they are special....
Btw, what is the difference between the different kinds of resistors.
Are there sonic differences f.ex between the blue 100 k, and the smaller 100 k resistoers>
www.paradisepi.com
PostPosted: Fri May 08, 2009 4:29 pm
Great pics and "Congrats"
Cheers
PostPosted: Sat May 09, 2009 12:35 am
Ok, iv'e been playing around for a while, and the more i play, the more i am convinced something is wrong.
Theres just not enough juice.
If i want a nice clean sound without breakup, it is far from loud enough.
Any suggestions is appreciated. I am clueless....
Don't get me wrong, it sounds great, but i wont be able to gig with it.
Even those small clubs i gig in.
www.paradisepi.com
PostPosted: Sat May 09, 2009 7:05 am
Please measure the voltages and post them as well as compare them to the manual.
Can you give some examples of where the controls are under these circumstances. I've heard this amp gigged in decent size venues and it's plenty loud for that.
PostPosted: Mon May 11, 2009 5:14 am
Found an error which i corrected, and then i measured voltages.
However i did get more juice after correcting the error.....
Pin 3 on V5 wasnt connected.......i just went straight to V4.
Anyway.
Goes like this
Code:
[b]Pin:      1       2       3       4       5       6       7       8
V1           135     -     1.19      -       -    136.3     -       1.2
V2           165     -    1.2        -       -    261.9     -    167.5
V3           243     -   64.2        -       -    244.3     -      64.4
V4             -       -   7.48     -       -       -      358      -
V5             -       -   7.47     -       -       -      357      -
V6             -       -     -       -       -       -       -     362
V7            85     -    1.64       -       -    120       -      1.67[/b]
V3 pin 1 looks suspicious, as do V7 pin1. Also pin 7 on V4 and V5.
And V6 pin8.
Off course i have no clue of what this means.....
Anyone....[/code]
www.paradisepi.com
PostPosted: Tue May 12, 2009 7:35 am
I need to look this over and and respond.
PostPosted: Tue May 12, 2009 9:14 am
Haven't read the whole thread so maybe this has been pointed out...
but one of the sheilded i/p wires on each 3 terminal soldering strip is going to ground!!
Stew
PostPosted: Tue May 12, 2009 11:29 pm
Actually they both did :oops:
Changed that already though, but thanks for pointing it out.
The amp still sounds gorgeus.
I can almost nail Robben Fords sound on talk to your daughter:-)
Stephen, looking forward to your comment.
Nicolai
www.paradisepi.com
PostPosted: Wed May 13, 2009 7:19 pm
You have nailed the voltages. I think it's perfect. Now Enjoy!!
Glad to hear it "sounds gorgeus" , it should. Some clips - please?
