It is currently Tue Jul 16, 2024 9:23 pm
PostPosted: Sun May 17, 2009 1:28 pm
I wired up the pt, ot, heaters, rectifier, mains, etc. I tested as instructed on p 33 of the build guide. Im only getting 3.3 vac to the heaters.
Any ideas?
PostPosted: Sun May 17, 2009 3:10 pm
Any ideas?
1, you're measuring from tube pin to ground instead of pin to pin.
2. you used the center tap of the filament winding instead of the two proper windings.
Stew
PostPosted: Sun May 17, 2009 3:54 pm
There should be 3.3 VAC between each green - green yellow pair. First check that is true.
PostPosted: Sun May 17, 2009 5:45 pm
I was measuring tube pin to ground. Where should the ground lead from the meter be attached to?
PostPosted: Sun May 17, 2009 6:43 pm
Use the AC setting and measure pin to pin.
Anywhere on the chassis should do :P
Users browsing this forum: No registered users and 49 guests
