It is currently Tue Jul 16, 2024 9:37 pm
 Post subject: Help--Very low volume!!
PostPosted: Sat May 23, 2009 12:09 pm
It works, but the volume is VERY low. Like less than 1 watt. Any Ideas?
PostPosted: Sat May 23, 2009 12:16 pm
Start by checking all the voltages & see how they compare to the posted / dcoument ones. Post them here if you can.
PostPosted: Sat May 23, 2009 12:20 pm
When I check the voltages, do I ground the meter to chassis ground even though Im checking vdc?
PostPosted: Sat May 23, 2009 12:23 pm
For DC voltages on the tubes, board - Yes. For AC only sometimes.
PostPosted: Sat May 23, 2009 12:59 pm
I can t get a reading on pin 6 of v2. Any suggestions?
PostPosted: Sat May 23, 2009 1:06 pm
How about on the turret board on the + side of the 16uf cap? Or on the pot side of the 2k2 2watt?
PostPosted: Sat May 23, 2009 1:08 pm
Nothing on the cap, and 5.0 on the pot side of the 2.2
PostPosted: Sat May 23, 2009 1:10 pm
But you had good readings on pin1&6 on V1??
PostPosted: Sat May 23, 2009 1:11 pm
Is the jumper underneath, in the right place? Check back for continuity.
PostPosted: Sat May 23, 2009 1:12 pm
Correction, nothing on the 2.2. if I keep the probe on it as it powers up the voltage rises, but then it cuts out and wont give me a reading
PostPosted: Sat May 23, 2009 1:15 pm
on pins 1 & 6 of v1 I get 133
PostPosted: Sat May 23, 2009 1:16 pm
Coco is probably right.There's a jumper underneath the board that brings the high DC voltage from the o/p end of the board. It's the dashed line on the color layout print.
PostPosted: Sat May 23, 2009 1:20 pm
there is continuity between those two points
Well V1 get's it's plate voltage (1&6) from the + side of that cap I asked about. :?:
PostPosted: Sat May 23, 2009 1:22 pm
Sorry JCR ..I gotta run (breakfast with the girl friend ;-)) Best Of luck. I'm sure Coco will chime in.
Stew
PostPosted: Sat May 23, 2009 1:28 pm
Correction, Im getting 237 on the + side of the 16uf cap
PostPosted: Sat May 23, 2009 1:38 pm
Im getting .27 on the point where the .022uf cap and the 470k resistor meet on the tube side of the board just to the left of the 2.2k 2w.
PostPosted: Sat May 23, 2009 2:16 pm
Is your 56K resistor grounded to the buss bar?
PostPosted: Sat May 23, 2009 2:41 pm
and is the jumper on v3 pin 8 to 3 ?
PostPosted: Sat May 23, 2009 2:59 pm
Yes to both
Users browsing this forum: No registered users and 57 guests
